Crank won't turn on Honda GXV140
rejiii
Ok, forget the used parts comment; it is running like a top. After replacing the crankcase on Ebay, installing the new piston/rings, and connecting rod it runs like a top. The only gotcha, solved by a local Honda mechanic, involved a sheared flywheel key, that screwed up the timing, when I didn't tighten the ignition coil tight enough and it hit the flywheel while running - rookie mistake.
Another bucket list item out of the way.
P.S. If you install a new connecting rod be sure to mark the end cap/connecting rod to ensure the rod is installed exactly as originally milled onto the crank shaft. Reverse it and it probably won't let the crank shaft turn.
