Insanity42
I have a Craftsmen Model 917.388861 6.5HP 21" cut walk behind mower that I recently replaced the blade. It seems that since then the mower is either burning oil or overheating after 10-15 minutes of operation. During operation there will be low amounts of white smoke coming from the engine and when it is turned off, the exhaust becomes a heavier white smoke. As I also recently added oil, I thought that perhaps I overfilled it so I drained it and added fresh oil (5W20) but the problem continued. I am not sure if the carburetor may be a problem?
Any feedback is welcomed. I have used this mower for years without a problem, and this did not developed until I changed the blade. It almost sounds like the balance could be off if that is possible.
