Craftsman zts 7500 lurches
tj7740
My Craftsman zps 7500 lurches at all but full speed ahead. I'd appreciate any suggestions.
Briana
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Craftsman Forum. You'll get a better response there. :thumbsup:
mustang
hellllooo... I am having the same problem and we are in the craftsman forums. can anybody help us? is this something I can repair? HELP please
7521
I had the same problem with an older model and it turned out to be debri in the carb. after a thorough cleaning the issue went away.
If it "Lurches" in time with the engine then you have a fuel deliver problem.
If it lurches without any change in engine rpm then you have air in the hydraulics and they need to be bleed.
Note "they" both sides.
The QC on Craftsman now days is on par with stuff from China.
And the pre delivery down here is non existent.
Just done 3 Craftsmen all with less than 100 hours all had the decks nearly 2" lower at the front all had bent blades ( wonder why ? ) all had wrecked spindle bearings and all drove really crocked no matter how much I adjusted them
