Craftsman trimmer no fuel?
juntjoo
Should I be able to blow through this inlet? It's the fuel inlet, not the primer bulb one.
Depends. Are you holding the metering lever down to open needle valve? now if you got the crab disassemble then yes.
I don’t think so, if you still have the diaphragm mounted on the backside, under your finger.
Basically the fuel in side is open when you got the fuel pump cover off so air or fuel should flow through to that side and the fuel cross flows thru the metering needle valve to diaphragm side. The engine vacuum opens the metering needle valve by depressing the metering lever.
One the main problems with these carbs is that the metering diaphragm get stiff and can't open the metering needle valve
juntjoo
Doesn't even know seem to be working. Gonna watch some YouTube vids on this carb ...
juntjoo
So just pushing air into the carb should NOT push fuel in as only suction through the diaphragm from the engine pulls fuel in?
juntjoo
So what does this say about new carb being able to push fuel into the carb? It's it just going as far as the diaphragm? Where is this a "metering valve"
juntjoo
Fuel is not push into the carburetor it is pulled into via engine vacuum moving the metering metering which opens the meterneedle valve which operate the fuel pump side of the carburetor.
The following cover Zama but theory cover all diaphragm type 2 cycle carbs.
Cool thanks. I'll look it over. What's "zama"? They make a lot of carbs we use?
