I have an older Craftsman garden tractor. Recently the tractor would start, but hesitantly. A few days ago I started it up.. ran for about 5 min and I turned it off, but it would not restart.
(1) Earlier the engine would start and turnover: when key is turned there is a click, but no start. When I turned the key a second time it would turnover. Now it will do neither.
(2) Battery is fully charged, plugs have been replaced, fuel filter is new, oil fine.
(3) Tried to start with jump from portable start battery, still nothing but a click.
(4) Checked the wiring, everything seems intact, fuse is good.
(5) Blades are disengaged.
(6) Have not yet checked the push switch under the seat (needs to be pushed in to start) - wonder if this could be the problem
(7) Within the past 4 years have replaced the ignition switch, coil.
Any suggestions?
THANKS
Any suggestions?
THANKS
