johnorlandi
Thank You for answering my first info letter. Now I have added photos to see if anyone has some good information. I may have to run a piece of safety wire to the throttle linkage to use it at ¾ throttle.
The only reason I am going thru this is that the tiller runs good and it is all I need to till a small piece of ground that I use for a garden.
I have taken several photos and hope I can explain it, so you can understand it?
First 3 photos are of the tiller, for identification
Photo #4 has a spring hanging down from the governor control, where does this spring go???
Photo # 5 shows the choke and throttle control
Photo # 6 shows the top of the carb with the choke linkage hooked up. I believe that is the only one I have correct
Photo # 7 looking from carb to governor control
Photo # 8 carb with choke linkage in place and throttle linkage going to the governor control. Could/may be wrong
How do I hook up the carb linkage so that I can use the throttle lever on the control panel,. Any help would be appreciated.
Thank You
John
Thank You
John
