Hi There..I have a question and hope you all here can help..
I have an older Craftsman Mower (model 917.258473) and it has a 15.5 OHV motor in it (model 28n707) and it gave me starting problems last year(dead battery and would just a click at times) and luckily it lasted the season. At the end of the last season cut, it had died on me all of a sudden and I just put it in the garage..
So put in fresh battery, plug,etc. to get it ready for this year..I turn the key and the starter just spins...The gear that is to engage the flywheel, will not pop up and make contact.. Is this a starter problem I take it?
Also, there are 2 wires that go under the flywheel that I do not what they go to. As I tried to mess with it last night, i seen some slight white smoke come up from that area(after I just happen to wash the tractor off).... any ideas?
Thank again for the help :thumbsup:
