Trcustoms719
- May 16, 2011
- 1
- 62
the steel pinion is used with the steel ring gear on the flywheel. the plastic pinion is used with the aluminum or plastic ring gear on the flywheel.
If it's plastic on plastic then it makes total sence.
I never saw a fly wheel with a plastic ring gear before, what kinda engine did that come on?
Aluminum ring gear and plastic pinion would make sence too, but i never saw one with that setup either haha.
I work on mostly 80's and 90's briggs and kohler engines.
I've had very few newer or older engines come in.
