I've been working on a 40 or 42 inch cut craftsman sit down mower, it had no spark. I changed the switch under the seat, then the ignition block, finally the coil. After the coil the engired fired up and runs fine. My new problem?
When I take my foot off the clutch pedal, to try and put it into a gear, OR, if I try to engage the blades, the engine wants to cut off. Also, the engine is supposed to cut off when I stand up off my seat but it does not.
Not sure if I put anything back in incorrectly, but there isn't much you can make a mistake with regarding the seat switch, or the coil. Unless the wires on the ignition block are crossed?
Look forward to some suggestions om what to try next. Thanks!
