Robert ==
Thanks for the financial run down. I think you're really Dave Ramsey or Clark Howard masquerading on this forum as Robert Brown. :biggrin:
My situation is weird. Without going into detail, money is very tight right now, and if all goes well, the house will go on the market in the Spring. I don't know where I might end up (could be an apartment, please God, no!) so I think this mower just needs to work for one more summer.
I plan to bury it in the yard the night before I move out! :biggrin:
I borrowed a gear puller from my neighbor today and tried to remove the blade holder from the motor shaft so I could remove the blasted v-belt. That blade holder wouldn't budge. Took the tool back to the neighbor, but he said, "Lemme come over and help ya. We'll get it off." BIG MISTAKE: Burly neighbor put the gorilla strength on it and POW!, the damned part
broke. Seems it's just cast iron crap.
So now I'm kinda screwed. I think I'll have to cut a slit through the side of the part (parallel to the shaft inside it) with a Dremel cut-off wheel, then heat it a little, pry it a little and she if she'll slide off. I haven't checked the Sears price yet because I'm
afraid too.
And the worst part is, the belt is probably fine. I just wanted to replace it "to avoid potential problems..."
LESSON 1: No good deed goes unpunished.
LESSON 2: Never let your neighbor come over and "help you."
Robert, I'm going to
disregard entirely your excellent suggestion to inspect the rest of the mower carefully. :wink: I can't afford a new one, and buying parts for this one stopped making sense about three years ago. So I'm going to repair the gear box for as little cost as possible, button it all back up and cross my fingers that she makes it until I close on the house...
If I'm forced to buy a replacement mower, I'm afraid I'll be using it as a coffee table in some post-divorce apartment next year. What a life... :confused2:
