Hello everyone, new to the forum. Browsed through here but did not find an answer to the problem I'm experiencing. First the mower I have and what I've done so far. It's a 2011 Craftsman rider, model # 917.288611, 54" cut, 26 HP kohler engine model # SV735. I bought it brand new, and through the years did some work on it. First I changed the solenoid, new battery, and plugs, also changed the ignition switch, and I converted the coil packs, this model had faults with the originals. This was done through out the years, just mowed last week and parked it.
Yesterday I go to start it and no power, the hour meter doesn't turn on? Try a couple more times, and it turns on, figure ok lets mow. She fires up, I notice the hour meter turn off, 3 seconds later the mower shuts off as well. So turn the key, and nothing, couple more times it gets power, hour meter is on. She fires up again, 3 seconds later, hour meter turns off, then the mower shuts off, loses power. Tried a different solenoid, different ignition switch, and does the same thing gets power, turns on and runs 3 seconds later, again hour meter turns off, then it cuts off as well. So seems like an electrically problem, it loses power even running? I'm thinking seat safety switch is going bad? Thinking I got off the seat?
Any help would appreciate it, need this lawn cut, and glad to be a part of the forum.
Marcel
Marcel
