The fuel solenoid will be at the bottom of the carb bowl, with wires attached to it if it has one.  Do you have 12v to the solenoid.  Without knowing how many terminals the solenoid has.  If it has two big terminals and two small terminals.  You need 12v to one of the small terminals with the key in  the start position, and continuity to ground on the other small terminal wire.
