craftsman riding lawn mower model 917.275013
Kohler engine
Battery not being charged
The stator is producing 40 volts A/C, BUT zero volts D/C
Also, when I push down the clutch pedal to start the engine, the engine runs, but quits when
I release the clutch pedal.
Also, I discovered that with the clutch pedal down, and the engine running,
when the PTO is engaged, the engine will quit. I disconnected the PTO clutch connector
but the engine still quits when the PTO is engaged.
I wonder if replacing the voltage regulator will solve the issue with engine quitting?
Kohler engine
