Craftsman Rider Won't start Using Ignition
bdurward50
I have a 4 year old LT2000 Model 247.288851 that will not start using the keyed ignition. I can set the parking brake, set something heavy in the seat, turn the key "on" and start it by using a jumper between positive battery post and starter. Runs fine, just won't start using the ignition. Using my meter I get 12 volts at the starter when I turn the ignition on. I get a good voltage reading coming out of the ignition on the meter also. I checked the parking brake kill switch and the seat kill switch with my ohm meter. The switch at the seat actually gave me a good reading, the parking brake switch didn't give a reading at all, so I put a new one on the mower. Didn't help. Anyone know what I'm missing? Could it be the ignition even if the starter is getting voltage from it?
Use this procedure to pinpoint the problem, my guess is the solenoid.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
I would try a new solenoid. I had the same problem with one of my riders where the starter wouldn't turn so I jumped it off from the battery and it worked so I got a new solenoid put it on and bang it started right up. I was getting the right volts to the starter and all but after testing the solenoid with the meter I was getting 12 volts in but not quite 12 volts out so I thought heck that's not right and changed it also changed the blade safety switch which was bad also. You also might want to check your ground wire and make sure it is grounded properly. I hooked mine us directly to the negative on the battery instead of on the frame of the mower. Tried to start it again after install and bang it kicked right off.
