stuffhappens
- Mar 25, 2021
- 1
- 2
Mower is about 12 yrs old. Governor was bent and had to be replaced. I have not been able to set the new governor correctly. I know how to set the governor, but there must be another problem. Engine idles to fast and when you open the throttle slightly the engine immediately revs too high. Resetting the idle screw is not the problem. The governor control shaft that goes thru the side of the engine may be bent, too. When I replaced the governor I tried to compare the old shaft with the new one and could not tell if it was bent. I would have replace governor shaft, but it looks like the crank has to come out to get the governor shaft out. Is there a way to get the governor shaft out without removing the crank? The governor spring on the linkage seems a little stretched could that be my issue with the governor setting?
