Craftsman Pro 25 HP V-Twin Kohler 54 Fabricated Deck Zero Turn Riding Mower
Leo G.
  • / Craftsman Pro 25 HP V-Twin Kohler 54 Fabricated Deck Zero Turn Riding Mower
I have this mower and it runs and then dies when fully engaged cutting grass. I dont know what is wrong with it but is the second mower from sears in 6 months and does the same thing. Need help to find out if there is something i can fix or that im doing wrong!!
mechanic mark
Post model number from under seat. Check by hand wire harness connection at PTO clutch at bottom side of engine.
Please run through your entire routing from the time you sit on the seat till the engine dies.
One step at a time.
Ie , sat down , selected neutral, engaged brake, disengaged PTO, etc,etc.
You are there we are not.
