I'm re-posting because I realized my first post wasn't very clear. After replacing the drive belt the mower doesn't want to shift and will barely move. I tried adjust the clutch rod but it didn't solve the problem.
My first thought would be belt is wrong size, I looked up tractor number you put on first post and sears doesn't pull anything up.
Check under seat and make sure you have right tractor number.
