Have the above riding lawnmover, someone did work on it, but could not fix it.
They changed the starter, soleniod and ignition switch. Unit will still not fire up.
No sound, nothing. Battery is good. I noticed the solenoid they replaced, does not
look like the original one, that can be purchased from the craftsman parts dept.
Does anyone have a diagram, how the wiring should go to solenoid.
Also, what is the best method to test the, 3 safety switched, there is one under
the seat, and the PTO and then the clutch on, the last two have 2 white and 2 black
wires. thnks in advanced.
