A the Briggs model 4456 77 2188 GS (Craftsman Platinum 724CC) engine made loud pop, then a small amount of gray smoke came out of the exhaust. Now the engine run loud. Checking the spark plugs I found one cylinder fouls the spark plug with oil, the compression on this cylinder show 150 psi, the opposite cylinder reads 170 PSI and does not foul the spark plug with oil. Any ideas on what has happened?
