sgkent
as stated in the last post, keep the starter fluid around or find the cause. The air to fuel mixture needs to be richer when the engine is cold. It sounds like either the choke or fuel primer bulb isn't working, or being used incorrectly. I had a carb on my edger that took maybe 20 squirts to get the engine to start when cold. Rebuilding the carb did not help. Then I replaced it with a new old stock one and it starts first pull on a couple squirts of the primer. Sometimes things just get worn internally in the carbs. If yours starts with a couple primes but dies over and over, that might be the fuel supply system. On many of the old carbs that is a small diaphragm that has a flap on it that acts as a check valve in a fuel pump. When they warp they don't seal. No seal, no fuel, so no run.
