Craftsman LT2000 (2009 I believe) Briggs and Stratton 19.5 hp
I was driving along mowing, and all of a sudden whenever I would idle (blades not engaged, parking brake on), the engine would rev really high, unusually high. Whenever I would begin moving and engage the blades the engine would idle normally. Then, in the middle of mowing, the entire tractor just shut off. I tried to restart it, and the engine just spins. This is just another issue in my saga that has included having the carb cleaned, adjusting the valves, replacing the battery (my fault on that one, left the key in the On position), fuel filter...
Any thoughts would be appreciated. Thanks.
