Craftsman LT2000 (917274822) Blade Brakes Problem
Need2learn
  • / Craftsman LT2000 (917274822) Blade Brakes Problem
Hello I had to remove the blades brake assembly while changing out the blades spindle, now I cannot figure out it one side goes back on for nothing.
The side grass shoot is on, can anyone help or point to where I can look to how to put this back. Thanks in advance for any help or suggestions.
I suggest you go to Sears Parts Direct and type in your model number. It will give you a parts breakdown of the deck and then you should be able to identify where the part goes. From your description we have no idea of exactly which part you are talking about. If you need more help, post back with a better description of what is going on. A couple of pictures would also help.
Need2learn
Thanks for your response I was just over thinking it, and I was able to put everything back fine, its been a while since I had that deck out.
