Craftsman LT1000 Riding mower - Bypass to mow in reverse
TimNC
I realize it is a safety feature... but being able to mow in reverse makes it difficult to mow my yard. I have some small areas that cause me to have to back up to get around objects and oh how nice it would be if I were able to mow, while backing up! Please help!
My mower is a 2014 LT1000.
Thanks in advance
There's a couple of you tube videos on how to disable the switch so you can mow in reverse also there are some knowledgeable folks here that can guide you as well. My new LT 1300 has an ignition switch position and a button to push for mow in reverse. My LT 1000 that passed to the great beyond was way older and didn't have many safety switches. The one video I checked out after a google search showed it to be easy enough just disconnecting a two pin plug. Five minutes max.
Used to be all one had to do was turn the key back one click & it would mow anyway ya wanted. Guess that changed huh.
Thanks for the info :)
