Craftsman lawn tractor 917.271051 charging system problem
Sidney
  • / Craftsman lawn tractor 917.271051 charging system problem
My tractor has a manual, & I look at the diagram on pg. 31 their is no voltage regulator just fuse, diode & 3 relays.
How do you check the charging system with this system.
Sidney
Kohler engine craftsman model # 917.271051
You will need to get the model and spec off of the engine tag. Sears doesn't say what engine is on your mower.
Sidney
Ok I'll look, thanks man
