Not sure where to start with this. I have been out in 40c Humidity all day trying to fix my sons attempt at repairing a elderly friends lawnmower. AFTER all he did kind of sort of take one apart two years ago in school. Sorry still venting. Now here in lies the problem, the original problem was a busted spring for the recoil on the pull cord. the he busted the throttle lever off flush with the mount.
So off it came and I got the lid and pull system back up and working. The when I started the lawnmower started up it almost threw me off my feet with the vibration. So I presumed that he hadn't put the blade back on properly. He hadn't, now here in lies the problem again. I repaired the throttle lever and put the cable back on, now I can not get the mower to start or when it chugs once or twice I push the lever full on rabbit, and nadda.
It is a Craftsman Model 944 366-170 rear bagger. 20" cut 4.0 motor, if I can get a manual, help suggestions, (and as much as I would like to smack my kid) NO! Anything else would be greatly appreciated
