letterpressman
- Oct 15, 2013
- 2
- 4
I hope to solve my problems here. I've been reading the thread list for a week looking for similar problems with solutions. Close but not quite. No pictures, it's just a garden tractor. It's a Craftsman Kohler Command CV20S garden tractor(917.273022) with a 46" 3 blade deck that clogs with grass and gives a rotten cut unless I keep the deck clean. It baggs leaves real well. I bought the display model in '99 with a 3 bin bagger and added a box grader to excavate the patio a few years back. I also added a ball hitch to pull a 6x8 box trailer around the yard to collect leave, grass and garden waste. It's been a real workhorse until last week when it started on only 1 cylinder. It appears that something has been chewing my wires. A neighbor fellow helped me diagnose the problem. We took the top shroud off the engine and 1 plug wire was hanging by a thread. Also a purple wire in the harness was stripped bare about 4 inches in the middle of the wire. one week and $70 later, I replaced the coil w/plug wire and taped up the bare wire. when I put it all back together, I find my friend removed a 3-4 inch black wire with a screw lead on both ends and a machine screw in one end the same type of screw that hold on the shroud. For the life of me, I can't figure where it came from or what it does. The engine runs on both cylinders. With no load the engine surges every 2-3-seconds(not much worse than before) and backfires out the muffler a lot! Could the mystery wire be the culprit? All the exploded views I found online are no help at all. As long as I'm moving and mowing, no problems. Any suggestions? I'll repost this as a new thread in hopes of finding an answer. Thanks.
