I have a ltx 1000 with a hydro gear transaxle model# 314-0510. I have had trouble with it slowing down when it gets warm(like almost everyone has this problem sooner or later). I took the unit out and opened the casing and replaced the pump and motor blocks, the thrust bearings, the center section, drive belt, flat idler pulley, bearings, seals and oil. When I put it all back together, I purged the system just like the manual instructed and I still have the same problem with it slowing down when it warms up. I also checked the bypass arm and the brake adjustment. I am at a loss with what to do next. I'm thinking that the new center section is leaking or the check balls are not seating properly. Can anyone help me figure this one out?
thanks in advance
thanks in advance
