Craftsman GT6000 with Kohler engine PTO to magnetic wireing question
vintageman
I have a Craftsman GT6000 garden tractor, with Kohler engine.
The bracket stop pin broke that stops magnetic clutch from turning freely. When the stop pin broke off the bracket, it allowed the clutch to spin, tearing loose the wires. I have two wires left on the clutch and the rest of the wires are gone. Where do the two wires to the clutch go? I believe one is a ground and the other is activated by the pto switch. Where on the tractor is the plug in connection for the two wires located ?
The wires run down the right side of the turret / console then through a hole and under the right hand side to the clutch.
Just where the wires go through the floor there is a 2 pin plug for the PTO.
Usually they are both powered an grounded through the PTO switch.
