Engine Craftsman Generator
What I was referring to was the stator housing; not the rotor to crankshaft. Sorta like a starter housing so the mounting screws/bolts don't touch the windings and wear though from vibrations.Now with the stator out alignment the rotor might sitting off center on the tapered crankshaft. Definitely don't want it sitting off center at 3600 rpm.
I took the generator apart, a lot simpler than i thought, i exposed the big winding and magnets on the crankshaft and the ones inside the housing, there is no binding. it all goes on straight and smooth, but i cant get that cover over the 2nd piece..... it is very weird..............
i can tighten the 4 rods down that pull the two halves together, but it only pulls from the 4 corners and the top wont slip over the edge of the 2nd cover.
Sometimes there is a small line up lug and slot that has to be meshed to have everything in alignment, maybe at the top of the case there, could be it's not just exactly lined up? Might try to put the top together first and draw in the sides and bottom?
