TiIngot
- Sep 9, 2022
- 52
Craftsman Tractor Model - 917.252510 - 42" Deck - 16HP Briggs
Transmission Dana Transaxle Model - 4360.79
This thing is about 30 years old. The engine was blown when I received it (no oil), and previous owner has no history to help. It came with the house. Just completed an engine swap with a 15.5HP Briggs, used the original motor dual belt pully and did a brake repair. Also used the drive belt that came with the mower. It remained installed and was only removed from the engine pully during the swap.
Now the first test drive. The gear shift moves easily when not running. The gear shift moves easily after starting the engine throughout its entire gear range with the clutch in.
Release the clutch/brake and it drives. Push brake and it stops. There is no sound or smell indicating the drive belt is under heavy tension when stopped. But the gearshift is frozen in whatever gear it was driving in, forward or reverse. The only way to shift gears or put it in neutral is to stop the engine. Then the gear shift can be moved.
At this point I cannot find a mechanical reason for the gear shift to lock up after the tractor moves in any gear. The clutch releases the belt tension, and the tractor stops and the drive belt stops moving, but the gearshift remains locked until the engine is shut off.
My first inclination is somehow, even though the belt is not moving there is tension on it that somehow locks the gear train in the transaxle until the engine is shut off.
Looking for suggestions please.
Lee
Ps: This is a winter hobby. In three years, I have rehabilitated nine tractors and sold none. They are given away to others. This one is earmarked for the neighborhood swim club if I can make it safe to use.
Lee
