TradesmanGuy
- Nov 3, 2011
- 3
- 23
My 22 inch Craftsman pusher, like the majority of front drive self propelled pushers, uses plastic front wheels with gears on the back side that mesh with the metal gears on the front drive assembly. Before storing every fall, I remove the front wheels (and rear) and powerwash the debris off the wheels and axles. May be a dumb query, but would it be a good idea to rotate the two front drive wheels side to side to even out the wear pattern from the metal gears, or would it be best to replace the wheels on the side they were removed from?
