bucfan7273
- Aug 3, 2021
- 3
I was wondering if I could replace the easy blade system on garden tractor, to something more durable. Thank you
You need for the conversion complete spindles. The housings are shorter on the Quick change system. Here is a side by side comparison with your spindle on the left. Note right spindle is the greaseable version but non greaseable is the same except no grease zerk. The addional length make for the lack of the blade adapter.2 blade holders are broke. Do I need a new spindle assembly or just the shaft?
Hi, I am also interested in replacing spindles on my Craftsman 917.986450, as they discontinued the EZ change mulching blades (plus the design overall was just bad). How would I know what spindles to order?You need for the conversion complete spindles. The housings are shorter on the Quick change system. Here is a side by side comparison with your spindle on the left. Note right spindle is the greaseable version but non greaseable is the same except no grease zerk. The addional length make for the lack of the blade adapter.
Thanks!Depend which you want>
587819701 Non-greaseable
587820301 Greaseable
Both retails for the same price each.
