Craftsman Eager-1 6.75hp won't run
mmanter
The running problem sounds like a fuel issue, but the OP hinted to something that makes me think we could have a compression problem. The OP said he replaced the head gasket, what did the cylinder walls look like. Any deep scratches, or gouges. If possible could you get a compression reading. It would narrow down the possibly causes for the running issue.
I will check for bulletins tomorrow to help out Rivets, since he couldn't find the bulletin. Seems like that bulletins came out several years ago, like early 2000's
There were no scratches or gouges in the cylinder walls. I noticed the head bolts didn't seem too tight & that there was quite a bit of carbon & oil around one of the head bolts so for good measure I went ahead & replaced the gasket to eliminate that as an issue. The cylinder walls actually looked in good shape for a 15 year old lawn mower engine. What should the compression be and what would be the best way to check compression?
The only way to accurately check compression is with a compression gauge. Compression should be 90 or above.
mmanter
OK Thanks. I have that at home so I'll check it & post the results.
Roger95
I'm watching this one as I have the same exact motor and problem. Was mowing one day and it just died. Pull cord and nothing. Hit primer bulb a couple times and fired up and just died. Mower is old and needs replacing anyways but am curious as to what causes this.
mmanter
Gave up on this engine. Found a non-vector 6.75 HP mower & decided to fix it instead of fighting with the vector. That mower is not a self propelled so I'm gonna take that engine & put it on this mower.
