Ok, now a different problem
The mower is no longer idling funny after the carb repairs but instead when I started the engine it was going fine but when I shut it off to empty the grass catcher it would not re-fire. After trying a few times I figure I flooded it so I shut it off to clear out. I recalled I had another spark plug that was good so I installed it but noticed that the carb is leaking gas out the air cleaner. The paper element is soaked with gas & gas is dripping on the deck of the mower. so it's clearly flooding. I replaced the old needle & seat, float was good, new gaskets all around & no blockages in the bolt that holds the bowl on. Fresh gas that just came from the same gas station all my other lawn mowers run on.
This thing is an old mower I just bought used & I just need to last the season but I have yet to be able get through one time cutting the front & back yard without problems. Any ideas?
