shylasgarden
Hi Everyone,
My mower blades started to turn to slow to cut, then would speed back up for just a minute or so then slow down again and was just to slow to cut. The belt was very loose so I put a new belt on (checked numbers, it is the correct one). When the deck was pulled out I noticed the spring tensioner was broke (the cable end) so I put a new one on. Now everything is together and double checked (belt is on correct as it came off and also according to the diagram) but as soon as I engage the blades it binds the motor and stalls it. Does anyone have any idea of what I could do or check? Thank you, Di
