Craftsman DLT3000 Wiring
dnice
Hello - Could really use some help as while I like to do a lot of things on my own, wiring & wiring diagrams are NOT my strong suit! I replaced my ignition switch this weekend as I was having some trouble with the tractor turning over unless I was pushing down on the key when attempting to start. After replacement I was still having the issue so I thought I'd take a look at the wire contacts. Of course instead of coming out 1 by 1, they all came out at once & I hadn't ensured I knew where each wire went. Now, I'm confused as hell on where each wire goes in the connector. I think I have it correct based on the diagram, but nothing is working correctly so I'm stumped. Also, I've already replaced the fuse so no issues there. Any help you can provide would be greatly appreciated! Pics are attached & my model number is 917.273470.
