Hi everyone,
New to the site... have to admit my project tractor is giving me fits, these days. I'm really hoping for some tips at what I need to direct my attention towards. Long story short...
Bought a used tractor as-is from a guy to wrench on and replace an old 44" tank that finally crossed the point of reason to work on. It's a Craftsman DLT2000 with a 25hp Briggs V Twin in it. Has about 850 hours on it. Thing was running and cutting when I picked it up. During the move an old siezed up plastic idler broke off, which I didn't notice and that had me scrambling. Blah blah blah. Few other items fixed as well. New plugs, new oil filter, new belts, patched gas tank, rebuilt the siezed up brake, cleaned out the carb. I had the thing running fine when I left it in someone else's charge, though I will admit I thought it was running slow (as in low top speed).
Fast forward a bit, during the second mowing of this property, I was called and told that there was oil everywhere. a couple of questions later, and I learned that she forgot to screw down the oil dipstick cap and that the oil was coming out of the top and covering that side of the motor, the fwd/reverse pedals and her feet. I took this at face value. She cleaned up, and didn't think about it again.
Got another call... now the tractor won't start. It's been sitting for about 4 days or so. Started once, ran for about 40 seconds and then stalled out. The engine cranks and sounds just like it did before, it just doesn't turn over and get on with it.
Spark plug wires are in place
Fresh gas in it
Choke is operating
Throttle adjusts as it should
Battery charged
Proximity switch at this point has been disabled for testing
Fuse iss good
Fuel filter is new and appears to be letting gas through normally
PTO is disengaged
Clutch is down
Key is turned ... heh
At this point I have to assume something bigger. Valves, carb flooding, something... right? This is the biggest small engine I've worked on, and the only twin OHV. So it feels like I'm reaching. But any help or tips anyone can give would be greatly appreciated.
Thanks everyone.
Fresh gas in it
Choke is operating
Battery charged
Fuse iss good
PTO is disengaged
Clutch is down
Thanks everyone.
