Mower deck craftsman DLT 2000 deck heighth adjustment
lvnlrge63
My mower deck height will not adjust. The problem seems to be in the handle mechanism. Any suggestions on what to try to fix this problem?
Have a close look at the handle where the locking pauls come out to engage with the height slots.
The handle is weak in this area and tends to bend if not break all together so the paul will not go down so it will not disengage from the slot.
Every thing that come out of the AYP factory with this mechanism suffers more or less from the same problem and another case of a factory refusing to fix a simple design problem.
On very rare occasion I have seen twigs or other debris blocking the pauls movement but usually the handle is bent .
you can straiten it but it will be weak & just bend again so it will either need a stiffener welded onto it or replacement.
lvnlrge63
Thanks Bertsmobile1. That gives me a heads up will check it out this weekend.
