I'm just trying to make sure I understand this all correctly as I've ordered the wrong parts before trying to correct the steering. (oops) It sounds like this is a common problem and maybe Craftsman has a replacement part to fix the issue but, I cannot for the life of me get the deck lid to level properly. I thought I read while searching that you can just order the exact same part that goes on the left to adjust the height and place it on the right side, that way you can adjust both sides? Has anyone done this and was it fairly straightforward doing the install yourself? I see on repair clinic (Craftsman lawn mower shaft 532195270). Does that sound correct? Thanks guys so much for any information!
Dennis
Dennis
