My mower has a 27hp kohler engine. The problem is that it will not start when it is cold. "Unless," I shoot starting fluid into the carb a number of times, then it will finally start and seems to run normally. When I turn it off and let it sit overnight it does the same thing, I crank it over till the cows come home and it will not start until I use starting fluid. Not good for the engine I know!
Any ideas?
Any ideas?
