Craftsman Briggs 17 HP miss-miss running in low idle
RussellTP
When it is running full throttle, it seems fine but when I lower the throttle then it runs miss miss. does anyone know whats the problem?
Briggs 17 HP OHV
Dirty idle passage way in the carb. Best fix, remove, clean very well with a soaking, rebuild with a rebuild kit, reinstall, should be good to go.
