Hi all,
A few days ago I bought a used 20" 6hp Craftsman lawnmower. The seller demonstrated the mower and it was working fine... I brought it home and gave it a more thorough inspection, found that one of the rubber hoses needed replacement, needed more oil, the spark plug was loose enough for me to unscrew it with my hand. I fixed all these small issues, started the mower and almost immediately the rpm started going up and down. I managed to mow some of the front yard and then the mower finally died. I tried restarting it and it wouldn't start again. Then I removed and cleaned the carburetor, blew all the little holes with air compressor, put it all back together and the mower started again. I mowed my entire front yard fine, the rpm held steady and I had no issues. Then I moved to the back yard, it started fine again, I mowed over half of it and the problem came back. First the rpm started fluctuating and finally it died and would not start again. It then started raining and I called it a day for mowing. I'm thinking maybe debris coming from the fuel tank and clogging the carburetor? Anyone has any ideas?
Thanks!
Thanks!
