marinesteban
- Aug 4, 2014
- 1
- 3
Good morning, new member here.
Have a 2yr old craftsman lawnmower that has been stored for a while, I took it out and try to crank it but it wouldn't.
I pull apart the carburetor and clean it up, new air filter and new spark plug; I also had to take apart the muffler as it was missing one of the bolts.
After putting everything together, it cranked up onthe first try but with a thick cloud of smoke and a violent shaking, a few seconds later it dies; it also sounds like something is grinding.
I pulled the filter after that and is clean, however, the muffler is flooded with oil, the oil level is slightly above the high mark.
Here are some pictures of the unit, the exhaust gasket, and a video
Any ideas or should I call the exorcist?
Thanks in advance.
Thanks in advance.
