- Aug 21, 2018
- 567
You need to remove the Flywheel to properly check the key. Perhaps you just looked at it.Hi all,
I am working on this mower and she won't start.
Cleaned carb with brushes and wire it is definitely getting fuel.
New air filter. Drained fuel tank and using new fuel.
Plug measures 15000 ohms which is good and light tester
lights when cord pulled. Sometimes pull cord kicks back and
sometimes there is a small back fire through the carb.
Checked flywheel shear pin and looks great.
Any other ideas?
Many Thanks in Advance.
PopIggy
