Have problem with craftsman riding mower going up an incline(hill). Belt is tight and turning transmission ok, so it seams.
Checked oil in transmission, OK. Just has no power going up hill. Runs ok on level ground. If you have the mower jacked up from the rear ( rear wheels off ground) and you have the engagement lever in back engaged, should you be able to feel tension on wheels if you rotate them by hand and the fan should turn?
