This weekend I was mowing the lawn with this tractor and then turned it off. I started it again mowed some more and turned it off. Everything was working properly to this point. I ate lunch, and tried restarting it. It would crank, but wouldn't roll over. I just got done changing the oil and spark plugs 2 weeks ago. I also just replaced the battery.
Any advice as to what should be checked?
Thanks,
Rob
Thanks,
Rob
