Mower stops running after engine gets hot (approximately 30 minutes)...Any advice?
J jerrye Forum Newbie Joined Aug 24, 2013 Threads 1 Messages 2 Aug 24, 2013 / Craftsman 917.270514 #1 Mower stops running after engine gets hot (approximately 30 minutes)...Any advice?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,778 Aug 24, 2013 / Craftsman 917.270514 #2 Next time it happens check for spark. I'm guessing no spark, which means the coil is heat shorting, which means replace the coil.
J jerrye Forum Newbie Joined Aug 24, 2013 Threads 1 Messages 2 Sep 2, 2013 / Craftsman 917.270514 #3 Thanks Rivets It passed the spark test...Any other suggestions?
Fish Lawn Pro Joined Aug 2, 2013 Threads 11 Messages 5,130 Sep 2, 2013 / Craftsman 917.270514 #4 Check and adjust your valves, .003-.005 intake, .005-.007 Check the rocker arm studs, etc., for tightness.
