Craftsman 7.5 HP Lawn Tractor idles down and blows smoke
wboone11
  • / Craftsman 7.5 HP Lawn Tractor idles down and blows smoke
My Craftsman Lawn tractor starts fine, but then it idles down , then revs up and blows a cloud of either smoke or gas fumes to the point its unusable. I changed the oil and it worked fine for cutting my lawn once, but when I started it a couple weeks later the problem is back. Help please.
SONOFADOCKER
If you do not use a fuel shut off in your gasoline line - your carb is leaking gas into the engine oil , muffler . When you try and use it the oil heats up and ignites - very very bad for the piston & crank . Fuel shut off is $2.00 . Close the valve before you park the tractor . let the engine us up the fuel in the carb - no more problems . Remember to turn the key off .
Rebuilding the carb would also help.
wboone11
Thank you Sonofadacker. Tried your suggestion and it worked great. Saved me a lot of money. Again thank you and all replies
OzRanga
If there is fuel in your oil you also need to change the oil as soon as possible, before you get a rude shock and the engine fails!
Have to tell you this that your problem is still there, you only put a band aid on it. I hope you never forget to shut everything off. Any good mechanic fixes the problem, thinking of the safety of the customer, even if it costs a little bit more. I wish you good luck. BYE
Carscw
Yes rebuilt the carb.
Sent from my iPhone using LMF
