Was given a Craftsman 21" self propelled mower today because it wasn't running. 6.25 hp, I believe the motor is Tecumsah (sp?), carb has aluminum bowl. I put fresh fuel , oil, and plug in it. I have spark. It wouldn't even try to start (no fuel) so I took off the jet screw on bottom of fuel bowl and cleaned it up (wire through the hole). Cleaned float and bowl, reassembled. Starts for 2-3 seconds on 3rd pull now then dies. Primed several times.....fuel now running into air filter tube. Is a needle stuck in the carb? Please advise on how to fix this, I'm handy enough, but not knowledgable on little carbs. Thanks so much.
