primerbulb120
- Nov 3, 2014
- 43
- 1,315
The primer bulb is supposed to pressurize the float bowl, causing gas to come out the main jet into the carb throat. However, the air filter base can become warped and allow the pressure to leak out at the gasket between the air filter base and the carb. This problem can sometimes be fixed by putting two gaskets instead of one between the air filter base and carb, but in more severe cases I have to apply gasket maker around the gasket to seal it. Works good if you do it right and it's cheaper than buying whole new air filter base.
Also, your primer bulb is supposed to have a small hole right in the center, like this: http://www.ebay.com/itm/SMALL-ENGIN...733978?hash=item35c913069a:g:ceUAAOSwf-VWVRN7
If your primer bulb has no hole, you probably have the wrong primer bulb for your engine. (I say probably because I've never seen one of these 190cc engines that required a no hole primer bulb.) The no hole primer bulbs are for the smaller (3-4.5 HP) Briggs engines.
I hope this post makes sense, if it doesn't I will try to clarify. :laughing:
